Old 05-01-2013, 06:58 AM   #11 (permalink)
Xist
Originally Posted by mcrews View Post
you whant corplast.
See my third thread in my signature.
ABS is not rigid enough over the distance and you'll have tooo many mounting points or too much vibration.
The mfg use abs because they can press in shapes to reduce the vibrating
Coroplast is more rigid than ABS? I mentioned the other day that if I ever did purchase a Prelude I would want an ABS belly pan because I regularly bottomed-out. I did see that you mentioned a discussion on materials, but I do not remember reading it.
Well, if it is good enough for a Q45!
