Old 05-01-2013, 05:58 AM   #11 (permalink)
Originally Posted by mcrews View Post
you whant corplast.
See my third thread in my signature.
ABS is not rigid enough over the distance and you'll have tooo many mounting points or too much vibration.
The mfg use abs because they can press in shapes to reduce the vibrating
Coroplast is more rigid than ABS? I mentioned the other day that if I ever did purchase a Prelude I would want an ABS belly pan because I regularly bottomed-out. I did see that you mentioned a discussion on materials, but I do not remember reading it.
Well, if it is good enough for a Q45!
Old 05-01-2013, 09:35 AM   #12 (permalink)
Busting Knuckles Often
Blue Maxx - '04 Chevrolet Malibu Maxx LT
Team Chevy
90 day: 26.96 mpg (US)
Tink's Van - '08 Chrysler Town & Country Touring
90 day: 19.09 mpg (US)
2004 5 Speed Goldrolla - '04 Toyota Corolla CE
90 day: 36.3 mpg (US)
Here are a couple of resources for ABS sheets
Originally Posted by tanjulio View Post
I am located in Modesto California.
I went to Lowes & HomeDepot. They have roofing plastic but it's wavy and wont work for undertray. Can anyone here recommend a supplier for ABS material or something comparable to make an undertray?
Thanks Sam
I am not sure if 1/16" thickness is too thin, or if you want to do what JoeG did and go with 1/8" thickness. I looked online for ABS sheets last year. Never saw in person.
Grainger will sometimes let you make a purchase without having a business account.
Link: Grainger Industrial Supply - ABS Sheets
Link: Fastenal | ABS Sheets
Old 05-14-2013, 08:25 AM   #13 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Originally Posted by JoeG View Post
It took 2 sheets and I got it from Industrial Plastic Supply for $45 per sheet.
Ouch!!
Edit: I got my coroplast from Piedmont Plastics for $11.50 a sheet..
Old 05-24-2013, 12:32 PM   #14 (permalink)
Both ABS and Coroplast come in different thicknesses so you match the panels to your particular needs. ABS is more durable than Coroplast in terms of heat or abrasion. The Coroplast is corrugated for stiffness. A coat of rubberized undercoat can dampen higher frequency vibration. Aluminum angle stock can be used to support panels and make hard mounts to reduce tearing.
Old 07-30-2014, 06:33 PM   #15 (permalink)
you may be able to find it online at abs plastic sheet they are great. i use them for all of my industrial plastic needs
