My FE Conclusion...
The comparison of 4 tanks using the additive vs. tanks during the same time of year (fuel fills from December-March, inclusive) were taken into consideration. The data set from the first Winter of 2005/2006 was noted as an outlier due to considerable experimentation, and not considered part of the Control Group -- Winter seasons in 2006/2007 up to 2011/2012 were considered.
Mean Average...
Control Group:
Sample Size = 39 fuel fills
Average = 32.61 MPG
TCW3 Additive Group:
Sample Size = 4 fuel fills
Average = 33.48 MPG
Is the increased average FE statistically significant?
Using a Single-Factor ANOVA at a confidence level of 95%...
The P-value was 0.53, F = 0.40, and Fcrit = 4.08.
Conclusion/Explanation: To qualify for the least validity, the P-Value needs to be 0.05 or less, meaning there is at least a 95% chance the data differs in a meaningful way. In this case, the P-value indicates a 47% chance -- which is very weak in Statistics. I also ran the full control group, and the similar Winter season of 2010/2011 -- the latter produced a P-value of 0.38: better, but still not significant.
Final Statement: TCW3 did not significantly improve fuel economy, based on previous Winter seasons; further, engine idle smoothness and occasional "stumbling" under load were noted as unscientific observations. Further testing is not considered at this time.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
 _
 _
