Thread: 3358 MPG Trip!
Old 05-02-2013, 01:36 PM   #5 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Yep, understood that that MPG number is theoretical and DOESN'T include the electricity.
I've run the MIT conversion factor numbers on my Electro-Metro, and it usually clocks in at 130MPGe. (including charging losses.)
The reason that comes in better than the Spark, Leaf, etc is just from driving slow! You can really sip the amps that way!
If I had properly clocked all the energy usage when I had it set up for a freeway configuration, I'm sure it would have plummeted to somewhere between 70-80 MPGe.
PS: I wonder what the true MPGe of a Prius, running on JUST the AC motor powered by a lithium battery pack would be? At that point, it's nearly an identical setup as a vehicle like the Spark, and has good aero. I wonder if just weight would be the biggest difference at that point?
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
