Old 05-04-2013, 11:38 PM   #19 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by WesternStarSCR View Post
Yep, called "i-Eloop". Not standard on all models. And not available yet.
I think one of the biggest bummers is, once again, drum roll please, the EPA test procedure that does not take advantage of start stop tech.
Mazda has had "i-stop" for years in other markets, but Mazda and other non-hybrid models won't bring it to USA because it is no advantage on EPA sticker MPG number.
It is pretty cool how it restarts: it stops at an exact position where a timed injection and valve opening will ignite one then the remaining cylinders to her it running again.
I may be wrong, but I believe the EPA is making provisions for stop-start. I think the only issue is that if it's an option, the manufacturer will have to certify both ways--with and without stop-start. Just double the work to certify.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following User Says Thank You to Diesel_Dave For This Useful Post:
WesternStarSCR (05-04-2013)
