Old 05-03-2013, 12:25 AM   #11 (permalink)
Busting Knuckles Often
Blue Maxx - '04 Chevrolet Malibu Maxx LT
Team Chevy
90 day: 26.96 mpg (US)
Tink's Van - '08 Chrysler Town & Country Touring
90 day: 19.09 mpg (US)
2004 5 Speed Goldrolla - '04 Toyota Corolla CE
90 day: 36.3 mpg (US)
Bump - Skyactive Diesel race car - no DEF needed
Mazda6 Skyactiv-D racecar gets first win at Road Atlanta
I am a new found fan of Mazda, and seeing what they are doing with ICEs without hybridizing. I am very technically curious.
I love the fact that they are using a non-SCR engine. I heard even the Cruze diesel will have to use DEF urea.
Getting around the cold start of a 14:1 CR with a bit of EGR for heat, and high temp fast glow plugs.
This thing is going to race in Detroit on Grand Prix weekend. Maybe I will actually go after all these years.
Old 05-03-2013, 10:32 AM   #12 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Originally Posted by ksa8907 View Post
Sounds to me like they are building a diesel with an engine they already produce but can't handle high compression. Sounds like a cheap shortcut.
The lower compression emits less NOx and gets most of the fuel economy. It works.
-Allch Chcar
Old 05-03-2013, 12:05 PM   #13 (permalink)
...beats walking...
...somehow, "pee-in-the-tank juice" (urea) just does not sound (smell?) intreguing at all!
The Following User Says Thank You to gone-ot For This Useful Post:
WesternStarSCR (05-03-2013)
Old 05-03-2013, 01:42 PM   #14 (permalink)
Team Chevy
& one more thing to worry about too...
DEF works for what it is designed for in our Class 8 engines where I work.
But for cars, not having a DEF tank on the Mazda 6, and not having to have a regen cycle etc., this will help user acceptance. And the price of DEF over the counter at auto stores is insane.
+1 for Mazda
Old 05-03-2013, 01:55 PM   #15 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
It still has a DPF, so there will still be regen cycles.
And before we all hail Mazda as being so wonderful for not using SCR, remember that the same decision has nearly bankrupted Navistar in the heavy-duty world.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 05-03-2013, 02:37 PM   #16 (permalink)
Team Chevy
I agree. Their whole engine business & future was riding on it though.
I am just glad about the Mazda engine being out there. Hopefully it will come with a 6 speed manual on the new 6.
Old 05-03-2013, 11:24 PM   #17 (permalink)
I think that the gas Sky-Active (sp?) engines also run compression ratios around 14:1. Oddly enough, I have seen several sources that suggest that is close to the optimum ratio for efficiency before the losses start to outweigh the gains with higher ratios.
I suspect that a lot of Mazda's thinking on ICE fuel efficiency has been worked through with the Wankel. They have done some interesting things with them. What comes to mind are the 6-port engines (the Wankel equivalent of variable valve timing) and shutting off the venturis for one of the rotors on decel. on some of the pollution controlled12a's.
Don't they also have an ultra-capacitor based KERS battery/alternator charge system?
Old 05-04-2013, 12:19 AM   #18 (permalink)
Team Chevy
Yep, called "i-Eloop". Not standard on all models. And not available yet.
I think one of the biggest bummers is, once again, drum roll please, the EPA test procedure that does not take advantage of start stop tech.
Mazda has had "i-stop" for years in other markets, but Mazda and other non-hybrid models won't bring it to USA because it is no advantage on EPA sticker MPG number.
It is pretty cool how it restarts: it stops at an exact position where a timed injection and valve opening will ignite one then the remaining cylinders to her it running again.
Old 05-04-2013, 11:38 PM   #19 (permalink)
I may be wrong, but I believe the EPA is making provisions for stop-start. I think the only issue is that if it's an option, the manufacturer will have to certify both ways--with and without stop-start. Just double the work to certify.
Diesel Dave
The Following User Says Thank You to Diesel_Dave For This Useful Post:
WesternStarSCR (05-04-2013)
Old 05-05-2013, 05:45 AM   #20 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Many people shut off the autostart function though.
In the NEDC autostart is allowed, but in real life you'll never see the big gains it gets on NEDC - which has numerous phases at standstill.
These were introduced to simulate traffic: accelerate, brake, wait, ...
