Old 05-06-2013, 05:39 PM   #31 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Originally Posted by sendler View Post
My Honda CBR250R scoops air with the fairing and sends it up the inside of the wind screen past the top triple clamp. Many newer bikes such as the new Ninja650 feature a wind screen that is spaced off of the cowl to take air up the outside and the inside surfaces of the screen. It is also a nice design feature as it makes the screen easily adjustable for height.
The original Vetter WindJammer of the Goldwing allows air to come up from under the fairing through the neck and triple trees also. There are also what would appear to be RAM Air scoops on todays bikes built in, but are actually closable air vents(as in A/c funnels) I would presume since there angled straight at the riders chest.
For newer bikes small air inlets for big windshields, are there to help reduce fogging or other various weather build up on the inside surface too..
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
