You cant wrap the cummins exhaust manifold, but you can JetHot it.
I Applied the Jet hot coating to a T4 turbine housing and while doing some welding on the flange it was bolted to, I could pick up and carry and move the turbine housing around as long as I was touching the ceramic, if I touched bare metal nope too hot, there is a big difference in heat transfer between coated and bare metal.
At some point I'd like to put on ceramic coating and then wrap my manifold. The issue with just wrapping is that it can trap moisture and rust the manifold in a hurry.
