Originally Posted by jeff88
So now the question is does the S3 have OTG? Also, having a UG already, I don't know how I can get Torque or similar to work, unless I get a splitter cable, but then I am eating up an awful lot of bandwith.
So a gyroscope will indeed work then? How would I go about setting it up? How do I know if my car has an accelerometer? Do I need that with a gyroscope or would that be a separate system?
Thanks!
With a OBD2 to Bluetooth adapter, you don't need an USB OTG capable device. And generally if your phone has a gyroscope, it'll have an accelerometer, too. For just reading gyro/accelerometer data off your phone, you don't need an OBD2 adapter, that's only if you want to use your phone as a 'scan gauge', so to speak, with Torque.
