Wow, I can actually pick that up and swap in my d15b 3 stage and use my ecu and call it a day. If I were you find another d16y5 and swap it in. Before you swap it in do all of the maintenance work. The ones you can't get to because the engine is in the car so right now since its out you do it all. Just make sure the engine is holding compression and everything else should be a breeze.
