Hello
Thank you very much for the Informations . I dont knew the Ratios from the AX exactly , i thougt my 1,4 has a 16x63 Differential like the 106 with the 1,4 Diesel. The 106 1,5 Diesel had 2 Ratios by the differential 17x61 and 17X64 , my 106 had the 17x64 .The 18x62 Gearbox has the Code CB55 but has the 5 Gear 41x35 .
The 47x32 is Amazing
i will search for it .
No Big Hills , never loadad .... You Lucky Guy , my AX has somedays a Hard Work fully loaded . i must reduce the weight but at first the lowering springs .
