Originally Posted by Rusty94cx
Get the exedy clutch it the oe one and like 100-125$. Cheap insurance. The hardest part of the job is probably the shift rod pin. Good luck and put an old clutch on it and do the test I posted in the link. That way you know before you put it in. And if it's not a cx/vx trans you can argue prior to install.
The metal part for the headlights is actually plastic and it's part of the whole housing. They are always broke. Junkyard. I could have got you some yesterday.
