235 miles, gauge is at 1/3...but needle fluctuates back and forth to half tank mark...
I overlooked the vacuum booster, assumed the article I read was normal for all HG's.. the marginal brakes may be caused by worn brakes out back...haven't had the drums off yet to see.
Your engine layout is very different from mine. Do you have a hydraulic clutch? What's with the little radiator?...my replacement radiator I had to buy actually goes all the way across the front, a touch longer than the leaking original.
Actually, a lot of changes under your hood...my batt is beside radiator..
