Old 05-12-2013, 12:53 AM   #17 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Oh got it! So you are just lowering the voltage to the pump so it doesn't get as much power = slower turning. Does that mean it is always turning slower than the rated amount or do you have a switch and on the absolute worst day in the worse circumstances, you can have it running full blast?
Did you test it to see how many diodes, experimenting with a couple then adding more as needed, or was there a way for you to figure out exactly how many diodes you needed?
Thanks for the help!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
