Old 05-12-2013, 02:48 PM   #19 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Originally Posted by echo-francis View Post
I use the diodes every time I drive but I switch them when my engine is at about 85C (if that happen ) initially i was using 5 diodes but when my engine is cold my ewp system make it turn on only 6v and 5 diodes lower the voltage from 6v to 3.5v-2.5v and it was to low for the pump. by just removing 1 diodes the voltage was lowered to 3.2v-4v and i think thats the minimun to make it turn
So you have it as a driver operated switch? Have you considered making it automatic based on various factors (specifically coolant temp, RPMs, etc.)?
What goes in the spot where the thermostat was, the coolant sensor, or does the radiator hose connect to the engine block directly? With no thermostat, how does the EMS know what the temp of the coolant is and how does it not throw a code/CEL?
At 85C, when you turn the pump on, what does the temp go down to (roughly)? Shouldn't the temp be right at 85C?
Sorry for all the questions, just trying to learn
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
