Old 05-12-2013, 04:45 PM   #18 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
I agree, the pendulum is a great idea, unfortunately, for this application I am looking for something a little different. It would definitely be fun to play with though!
I also like the DIY fluid inclinometer, but again, not quite what I am looking for in this application. I think of the two options, I would try this one first though as in my mind, it would be easier to read the markers on a vertical axis, rather than on a flat board underneath a pendulum. Both would make for some interesting projects though!
I found the apps for my Galaxy S3, but again, difficult to read while driving and I will have to remember to turn the app on when I get in the car (meaning it won't happen ) One inclinometer app I found has the degrees unit that I am looking for, though! (:
I couldn't find the G-Tech, but did find this: Electronic Magnetic Protractor I'm not sure if it will do what I want, but it has a small display which is what I am looking for. It says it displays in degrees or tilt angle %. I think the latter is what I am looking for (to match up with road signs as I mentioned in a previous post).
As far as the arduino goes, I think I will probably end up doing that, but will need a TON of hand-holding as it will be my first time. I *think* I found the ADXL335 board: ADXL335 and a display: Display
For the prototype shield board do you mean this: Prototype Shield Board or this: Mini Breadboard or something else?
What else would I need? Do I still need the Arduino itself? Would this: Mega 2560 or this: Arduino UNO be it?
Like I said, hand holding
If I can use the same hardware (i.e. main arduino board, display, etc.) for my grill block and anything else I might come up with, then less than $100 would definitely be OK! I'd be fine if the accessories end up costing a little more than something pre-done, because for one I will be learning and two, I will have one system to control multiple things.
I really appreciate the help!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
