Old 05-12-2013, 10:30 PM   #22 (permalink)
jere
camry wagon - '95 toyota camry LE
90 day: 23.99 mpg (US)
Originally Posted by echo-francis View Post
I never switch the waterpump off I only slow it down
I understand what you meant (REALLY COOL ingenious, method that is the first I have heard of anyone doing anything like that ) Sorry for the confusion I should have used the quote button. That post was directed at jeff88, didn't want him to think that one would have to switch the pump on and off while driving.
To jeff88 with my E-water pump ( just the pump no controller yet) I ran a relay off of the fuel pump so that I don't ever forget to turn the pump on and blow up the motor. The Davis-Craig might need some ignition source or something so it wouldn't need the same relay system I have. Maybe echo-francis can chime in on that? I am curious at least
Echo Francis are you using the Davis-Craig controller with your diodes or just one or the other?
