simple and easy to test
this is simple and easy to test
just log or graph calculated load at a certain speed on a certain road
2 directions 1 direction whatever
just be consistent
duplicate the condition of the test 1 for test 2
the fuel tank should be close to full at the beginning , it does not matter what kind of fuel as that fuel will be used for all testing -
the system will be at operating temp during all testing
we will not add fuel to calculate results there will be no related errors
use calculated load
if your modification reduces calculated load under consistent test conditions and you can repeat the results
then the modification is an improvement
if not
it is an UN improvement
its that simple
bring me the car
be aware
you will not be able to falsify your hoax in any way
we will be using my software and laptop
i will ride with you during the test and will be a witness
to the test results
- i will even upload them to this very thread -
ready begin
i eagerly await the replies of those who have HHO systems to be tested
i actually hope someone has a system that will pass the test
but color me very skeptical until that happens -
i can easily describe how to run the test for those with over half a brain and some simple equipment
my mom could run this test without assistance after the initial instructions
Reason: fuel
