05-12-2013, 12:29 AM
#51 (permalink)
Use yours and prove it.
05-12-2013, 01:07 AM
#52 (permalink)
MPGuino Supporter
iNXS - '10 Opel Zafira 111 Anniversary Suzi - '02 Suzuki Swift GL
Originally Posted by lastic
science has been wrong many times and hydrogen does work improving horse power and gas mileage get your head out of the sand and use your god given brain.
Grammar? Punctuation? Please?
05-12-2013, 08:19 AM
#53 (permalink)
Originally Posted by t vago
LOL! A guided cruise missile cat!
Fast Forward to 6:40
The Following 3 Users Say Thank You to IamIan For This Useful Post:
05-12-2013, 08:32 AM
#54 (permalink)
LOL, I may have had some sand in my hair from going to the beach, but at least I did not have to pay a proctologist to get it out of my @@#$%.
regards
Mech
05-13-2013, 12:01 AM
#55 (permalink)
simple and easy to test
this is simple and easy to test
just log or graph calculated load at a certain speed on a certain road
2 directions 1 direction whatever
just be consistent
duplicate the condition of the test 1 for test 2
the fuel tank should be close to full at the beginning , it does not matter what kind of fuel as that fuel will be used for all testing -
the system will be at operating temp during all testing
we will not add fuel to calculate results there will be no related errors
use calculated load
if your modification reduces calculated load under consistent test conditions and you can repeat the results
then the modification is an improvement
if not
it is an UN improvement
its that simple
bring me the car
be aware
you will not be able to falsify your hoax in any way
we will be using my software and laptop
i will ride with you during the test and will be a witness
to the test results
- i will even upload them to this very thread -
ready begin
i eagerly await the replies of those who have HHO systems to be tested
i actually hope someone has a system that will pass the test
but color me very skeptical until that happens -
i can easily describe how to run the test for those with over half a brain and some simple equipment
my mom could run this test without assistance after the initial instructions
Reason: fuel
05-13-2013, 05:56 PM
#56 (permalink)
DieselMiser
Hydrogen might improve horse power and mileage on an internal combustion engine but not when its generated by electrolysis powered by an alternator
The Following User Says Thank You to ConnClark For This Useful Post:
05-13-2013, 09:59 PM
#57 (permalink)
Yes, but you know how to spell, punctuate, and use grammar. And you believe in the laws of physics and thermodynamics. Therefore, you are not qualified to criticise the great god HHO.
The Following 6 Users Say Thank You to JRMichler For This Useful Post:
05-24-2013, 02:47 PM
#58 (permalink)
HHO is an attempt to use excess capacity of the system. It does not create free energy but burns fuel to create fuel via the alternator. Turbocharging is another way to use some of the excess heat and pressure generated by an engine. The net efficiency of the engine will increase with compression ratio and the reduction of internal drag. If you want to generate hydrogen try solar cells.
05-24-2013, 08:49 PM
#59 (permalink)
man i cant believe they put cats in bombs!!! WTF?!?!
05-24-2013, 08:53 PM
#60 (permalink)
MPGuino Supporter
That was clearly a cruise missile cat.
