Old 05-13-2013, 12:30 PM   #6094 (permalink)
jyanof
Joe
Originally Posted by johnsiddle View Post
On the current limiting front what do you think of the idea of instead of chopping the motor power zero and back up I over ride the throttle pot and drop it to say one third power with a slight delay on releasing. I feel it might be a little kinder on everything, it would still operate fast but a little smoother and I would still have some drive power.
I have already got a fail safe in that if the cct goes into over current for 1.6secs continuous (everything goes short and over current has no effect) then the main contactor is dropped out.
It sounds like you're writing your own software... is that right? If so, is your control scheme 'motor current' based? As in, the throttle is interpreted as a commanded output current and control loop uses the current sensor feedback to adjust the PWM duty cycle to match this commanded current?
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
