Originally Posted by Xist
Some Ecomodders have installed the antenna inside of the car. I do not know how they do that, but when I have a car worth modifying, I plan on installing a shark fin antenna.
Of course, I would need one of those with the Sirius radio that has been waiting in my closet.
Yeah, I could do that but I do not use my radio much, so that would be useless.
Originally Posted by payne171
Forget the Scangauge and go to Insightcentral for a OBDII C&C. It is a member designed device that does everything a Scangauge does plus it shows you what the hybrid system is doing. It allows you to control the state of charge gauge so that you can force charge the battery or stop a charge.
I would probably plug the two devices on a OBD-II splitter
. What is the price of an OBDII C&C?
Update : Today I went to VitroPlus Ziebart to install my insurrance transponder, they started my engine and made it idle for 15-20 minutes
. 76.2 MPG down to 71.7 MPG... I also decided to disable my electric power steering. I removed the EPS fuse from the engine bay fusebox. It works well, and my steering is still pretty easy to turn. I always have the "EPS" dash light tho.
