Thread: Windshield Trim
Old 05-15-2013, 10:21 PM   #1 (permalink)
Superfuelgero
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Windshield Trim
I looked in the search and aero lists without luck.
Replaced the windshield on my vx, and the trim is shot (top and side). They tired to reattach it, but its wore out. I could a) try to find replacements (haven't found any yet), or b) try to make something better.
The current setup is the windshield is slightly recessed into the chassis. the trim is flush with the chassis, and contains a channel along its base parallel to the windshield face.
Over the past couple of weeks i have looked at newer vehicle to see how aerodynamics have improved since then. Most now use the door frame to accomplish the same function, but are more flush at the top. Both styles look like the would create drag since the sides of the glass tapper towards the top (channel becomes a scoop). This is more pronounced in my application since the trim doesn't sit flush anymore, and creates a second channel of sorts.
Is this the best design, or would I be better of to form a trim piece myself that is completely flush out of windshield sealant (tape off, then use a caulking tool)?
Is it better to direct air out or up?
Is there a better way?
Is there another thread or site i should be looking at?
My goal here is to try to reduce drag, also to reduce noise.
-Aaron
