Old 05-16-2013, 12:43 AM   #305 (permalink)
RatherDashing
the other guy I work with has done quite a few transmission swaps and It all checks out great. he said he could shift and turn thru the gears. once I get the money were going to replace it with the clutch as well. he also mentioned about turning the fly wheel
we got a cherry picker at the shop so were just going to pull the whole engine and trans out at once to do it. the vx transmission weighed in at 90 lbs and had the p20/a000 stamp on it and the vin checks out and everything. can only hope for the best. but my milage blows right now with the z6 trans with the bad input shaft bearing in there
plus its getting harder to put into 1st and grinds sometimes going into 3rd. and the grinding at neutral and acceleration at 1st is getting louder.
