Thread: Wheels/tires
Old 05-16-2013, 12:34 PM   #12 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by Sean.Heihn View Post
You could almost think of a wheel as a radial lever working against you, the longer the lever (ie the bigger the diameter) the more the force is multiplied.
I've heard good things about Michelin Defenders. A tire's only job is traction, so that's the first thing I look at when shopping for tires, tread wear, noise, comfort and LRR come second. I'd rather avoid an accident than squeeze a few more miles out of a tank.
That really doesnt make any sense.
Then you should buy the stickiest tire out there.
by the way, what tire are you running?
And for being so accident adverse....looks like you 'settled' on the yaris.
If there is not room for 'other variables' in your thought process, then your current car fails.
or where you concidering mileage????? (also)
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
