Old 05-16-2013, 06:47 PM   #14 (permalink)
Mira
Captain Planet
Smokey - '00 Honda Civic DX
90 day: 38.53 mpg (US)
Jade - '02 Acura RSX Type S
Originally Posted by justme1969 View Post
Oversize drive tires can lower final drive ratio and get hiway mpg.
Quite a few posts in here on it for selection.
Yes, I plan to buy taller LRR tires with ideally, a stock width in the front and a notch or two slimmer in the rear. That would also leave more room for rear wheel skirts I reckon in one swift motion I may also swap for lightweight rims once I evaluate the stock rims weight vs. aftermarket options. Rotational weight, much more sensitive than dead weight.
Originally Posted by AndrzejM View Post
Nice sketches! And a nice target! But I'm sure that you can achieve that just by adjusting nut behind the wheel With all the mods that you have planned it will be much easier though
Good luck with the mods.
Absolutely, the nut behind the wheel is my most frequent adjustment I know I will be able to sustain 50mpg, the matter is how high a speed I can keep while doing so. I feel honored to have your support, I'm a big fan of Berta's
