Another question for you guys. In regards to Headers. I am thinking to install some to replace my old rusty manifold. Not only is it an admitted eyesore, but it's probably unnecessarily heavy as well. I read that short-tube headers are better for the low RPMs. Can anyone point me in a good direction as to which header style/brand would be the best for the low to mid RPM range? In my sharpest "pulses" my rpm usually never exceeds 3200, and that is only momentary anywho.
If I do this header mod I will likely also install a block heater while I have access to that sweet spot.
