Thread: Windshield Trim
Old 05-16-2013, 07:12 PM   #2 (permalink)
aerohead
VX
Originally Posted by xntrx View Post
I looked in the search and aero lists without luck.
Replaced the windshield on my vx, and the trim is shot (top and side). They tired to reattach it, but its wore out. I could a) try to find replacements (haven't found any yet), or b) try to make something better.
The current setup is the windshield is slightly recessed into the chassis. the trim is flush with the chassis, and contains a channel along its base parallel to the windshield face.
Over the past couple of weeks i have looked at newer vehicle to see how aerodynamics have improved since then. Most now use the door frame to accomplish the same function, but are more flush at the top. Both styles look like the would create drag since the sides of the glass tapper towards the top (channel becomes a scoop). This is more pronounced in my application since the trim doesn't sit flush anymore, and creates a second channel of sorts.
Is this the best design, or would I be better of to form a trim piece myself that is completely flush out of windshield sealant (tape off, then use a caulking tool)?
Is it better to direct air out or up?
Is there a better way?
Is there another thread or site i should be looking at?
My goal here is to try to reduce drag, also to reduce noise.
-Aaron
HONDA's already 'optimized' the A-Pillar/rain-gutter aerodynamics in the wind tunnel.
There would be other areas of the car to modify which would better reward you at the gas pump.
If noise is a problem (I've driven the VX and don't recall a problem) I'd look at the side mirror itself.
You'll see modern mirrors with excresances designed in to alter the resonant frequency of the plastic shell.
