Old 05-17-2013, 05:50 PM   #4 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Gas or turbodiesel?
My car is gas, but I was wondering from a general perspective as well.
I get the concept of the engine working to push the exhaust out, but legality aside, is there a length that is necessary for best efficiency to keep some back pressure (which I believe is necessary to have some), but not be so long that the engine has to work more than necessary to exhaust the gases. I assume it is based on engine size/power, but is there a generic rule of thumb?
Also, no inspection in California, just smog check.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
