Old 05-18-2013, 03:48 PM   #3 (permalink)
Wolf_Tm
I also found it had a carbs' cut-off device and a different from base Ritmo gauge:
instead of the tachometer, it had a consumption meter, a vacuum meter and a light for the "eco" correct gear change.
Originally Posted by Pandaf View Post
I seem to remember these models also had an early version of a start-stop system for the engine to prevent unnecessary idling. Is my memory correct?
You remember correctly!
Till 1985 it even received the "Citymatic", very first version of "Start&Stop":
Wolf_Tm250 [Silat-Kali] - Parma (Italy)
Suzuki Gsx-R 600 naked
Toyota Rav4.1 Torsen: 240hp 3SGTE swap in progress
Toyota Celica Gt-Four ST205 Snowy White [2.34kg/hp - 600Nm@4950rpm]
EFI University Advanced Tuner
The Following 2 Users Say Thank You to Wolf_Tm For This Useful Post:
aerohead (05-18-2013), Piwoslaw (05-25-2013)
