I also found it had a carbs' cut-off device and a different from base Ritmo gauge:
instead of the tachometer, it had a consumption meter, a vacuum meter and a light for the "eco" correct gear change.
Originally Posted by Pandaf
I seem to remember these models also had an early version of a start-stop system for the engine to prevent unnecessary idling. Is my memory correct?
You remember correctly!
Till 1985 it even received the "Citymatic", very first version of "Start&Stop":
