The way I've read it should be done for a Miata, which I'm not sure if it's true for your application, is to also loop the other 2 lines together after turning the wheel from lock to lock a few times to remove most of the fluid in the system. I imagine that it will still take a lot of effort to steer a car as heavy as a Grand Prix at low speeds.
