Old 05-22-2013, 12:49 AM   #5 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Jakins View Post
yah i know the final drive is the only difference. the 3.25 is what im looking at. i guess the dx is like 3.8 or something which isnt as good as m HX tranny. ive looked it up and talked to turbovr4guy and he said all of his vx cx trannys have the p20 cdoe with a J first. and from my research the dx/lx had a C first and the EX/si has a Y first. if this is correct then it should be very helpful because i cant find it listed ANYWHERE on the internet.
that is a great way to test it though california civic! thanks man, im not totally sure how many clicks the thing has to be with the tranny outside of the car to put it in 4th but i can figure it out.
anyone know if all of the VSS work the same in any transmission or do i need to get the vss gear that comes with it?
The VSS should be the same, fifth or sixth generation. They report 60 mph at 1025 rpms of the VSS gear. And the speedo gears inside the tranny are the same size too, whether black or white, though shaped slightly differently.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
Jakins (05-22-2013), vrmouseyd15b (04-27-2014)
