Old 05-24-2013, 02:47 PM   #58 (permalink)
Grant-53
HHO is an attempt to use excess capacity of the system. It does not create free energy but burns fuel to create fuel via the alternator. Turbocharging is another way to use some of the excess heat and pressure generated by an engine. The net efficiency of the engine will increase with compression ratio and the reduction of internal drag. If you want to generate hydrogen try solar cells.
