Old 05-28-2013, 01:04 AM   #10 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
When I am cruising at 65 and I put the trans in neutral the UG shoots up to some crazy MPG # like 300. But at lower speeds, the MPG in neutral is lower (like 250, 200, sometimes less than 100 at lower speeds). At first this made sense to me, because I have more momentum from the higher speed, but after thinking about it and verifying today, the engine revs at ~1,000 RPM no matter what speed once I put it in neutral. So my question is why I get higher mileage at higher speed (in neutral) compared to lower mileage at a lower speed (in neutral)?
Thanks!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
