Old 05-28-2013, 01:24 PM   #5 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Thanks for the link! I like the idea of being able to read the power coming into the house.
Yeah, I definitely don't want to be dealing with rewiring the fans, but if I ever get around to swapping them to different ones, I might do that before I finish the full install.
So a PWM AC fan wouldn't work. What about it is not a good idea? Would converting the power to DC than PWMing that be beneficial or would the inefficiencies of converting the electricity not be worth it?
Maybe if one has some forethought, they could use DC from a solar array and/or wind turbine and install DC fans. Would this be more efficient than standard AC fans? Also, in this case, would PWM be beneficial?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
