So what your saying is that any large equipment should have heavy wheels. So the heavy vehicles that have those large beams come out of each side to help hold it down should have heavy wheels. Basically for any passenger vehicle used for normal use, heavy wheels aren't really necessary.
Is this correct?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
