Old 05-30-2013, 03:00 AM   #137 (permalink)
talonts
VFAQman
talonts's Avatar
Originally Posted by mechman600 View Post
Overall, I found the quality to be much much higher than I expected. All I need is a sheet of treated plywood and I will be set!
You might want to consider the expense of a sheet of diamond plate aluminum. I used it on mine 8 years ago, and it has held up better than the rest of the trailer. Meanwhile, the plywood on the 4 year old trailer has rotted through, even though it was painted on all sides. And it will stiffen the trailer a lot if you decide not to fold it (the small casters are largely useless on anything but very smooth concrete).
Oh, and tighten the CRAP out of those frame bolts - mine is permanently tweaked, I'm going to have to use a come-along or something to flatten it to weld all the non-foldable joints sometime soon.
Tom Stangl
* http://www.vfaq.net/
* Prius Visual FAQ Home
* 04 Prius AM #7
* 06 Prius NL #7
* http://www.vfaq.com/
* DSM Visual FAQ home
* 90 Talon AWD Turbo
The Following User Says Thank You to talonts For This Useful Post:
mechman600 (05-30-2013)
