05-20-2013, 02:52 AM
#131 (permalink)
Ha! You got me to read a whole page before I figured out it was 2010.
Now to ensconce it with a coroplast aeroshell....
Well?
05-20-2013, 02:58 AM
#132 (permalink)
I couldn't find any coro out in Cali so it came back naked. That's the long trip where I really could have used it.
05-21-2013, 03:42 PM
#133 (permalink)
In the fasting lane
and if you can't afford to buy one...
 lifetime FE over 0.17 Gmeter or 0.1 Mmile.
05-29-2013, 05:28 PM
#134 (permalink)
Fusion - '16 Ford Fusion Hybrid SE
I decided to pull the trigger and buy the Harbor Freight 4X8 trailer. $294.
The first thing you have to know is that it is not the same as putting an Ikea shelf together.
Having a mechanical understanding is mandatory. For example, if you wire the ground wire to the trailer frame as directed, obviously no lights will work, as everything is painted and there are two hinge points that will not conduct very well. So I basically re-engineered the wiring, using dedicated ground wires for everything and loom for protection:
I also properly packed the wheels bearings with fresh grease as there was only a minimal amount in the bearings.
Overall, I found the quality to be much much higher than I expected. All I need is a sheet of treated plywood and I will be set!
The Following 3 Users Say Thank You to mechman600 For This Useful Post:
05-29-2013, 05:33 PM
#135 (permalink)
I'm not so good with electricals.
05-29-2013, 11:02 PM
#136 (permalink)
Yes that is the same trailer I have, but I tore mine totally apart this summer, welded everything together (it don't fold up any more). That was all after I put on an 1800lb axle, 1000lb each springs and 12'' 990lb each load range C tires back in 2009.
It appears that one of the hubs had locked up or burned up before I bought the trailer, that was part of the reason for replacing the axle since the spindles are welded to it.
My guess is the guy I bought it from ran the bearings with that "minimal amount" of factory grease and smoked one of the bearings.
I use lots of valvoline synthetic blend grease to pack the bearings.
05-30-2013, 03:00 AM
#137 (permalink)
VFAQman
You might want to consider the expense of a sheet of diamond plate aluminum. I used it on mine 8 years ago, and it has held up better than the rest of the trailer. Meanwhile, the plywood on the 4 year old trailer has rotted through, even though it was painted on all sides. And it will stiffen the trailer a lot if you decide not to fold it (the small casters are largely useless on anything but very smooth concrete).
Oh, and tighten the CRAP out of those frame bolts - mine is permanently tweaked, I'm going to have to use a come-along or something to flatten it to weld all the non-foldable joints sometime soon.
The Following User Says Thank You to talonts For This Useful Post:
05-30-2013, 12:48 PM
#138 (permalink)
05-30-2013, 02:42 PM
#139 (permalink)
Aluminum Dimond plate is expensive.
My trailer has 5/16'' aluminum dimond plate and the guy i bought it from claimed he paid over $500 for two 4'x4' sheets in 2005 when he bought the trailer and put it together.
Heck right now at lowes a >1/8'' thick sheet of 2'x3' foot aluminum is $100.
05-30-2013, 04:53 PM
#140 (permalink)
PlyMetal comes in 1/2-3/4-1-1 1/4" thickness with a baked enamel finish (8 colors) on one aluminum skin (top) and a mill finish on the other (bottom). I don't have a source or pricing, but based on the price of Polymetal, I'd hope for $200 for a 4x8 sheet.
VIP Swing Door -- white vinyl on the top, grey HDPE on the bottom
OSB Metal Plus -- Enameled aluminum/HDPE on Oriented Strand Board
Soak the cut edges in epoxy/polyurethane/beeswax.
