Old 05-30-2013, 04:57 PM   #544 (permalink)
aerohead
3D
I've read though a few important posts to get the intent of use out of the template. From what I can tell, it was originally intended to be used as a "quick and dirty tool", a start in the right direction for most.
Aerodynamic Streamlining Template: Part-A
http://ecomodder.com/forum/showthrea...part-9285.html
Aerodynamic Streamlining Template Part-B
http://ecomodder.com/forum/showthrea...rt-b-9286.html
Aerodynamic Streamlining Template: Part-C
http://ecomodder.com/forum/showthrea...-c-9287-2.html
If I can make a request, when it comes time to do a "Part-D", that it be 3D and include cross sectional information.
There was a thread to turn it into 3D, I'll find it later if someone else does not post it first.
Many months ago someone pushed and I went ahead a posted some extra views of the 'Template' I'd been working on.These were just working drawings.
I'm not sure how the thread was even titled.
A literal 'translation' of the 'Template' would be the 1/2-body generated from the 2.5:1 streamlined body of revolution from which it is derived.
It would be 'wide.'
Considering 'conventional ' body dimensions,the plan-view of the 'template' will look more like the low-drag 'section' profile of Hoerner's just to accommodate the more narrow vehicle.
