05-29-2013, 05:40 PM
#541 (permalink)
I've read though a few important posts to get the intent of use out of the template. From what I can tell, it was originally intended to be used as a "quick and dirty tool", a start in the right direction for most.
Aerodynamic Streamlining Template: Part-A
http://ecomodder.com/forum/showthrea...part-9285.html
Originally Posted by aerohead
Premise: The template is designed to be a quick and dirty reference for anyone contemplating aft-body streamlining to an existing vehicle or from a "body in white.
Aerodynamic Streamlining Template Part-B
http://ecomodder.com/forum/showthrea...rt-b-9286.html
-------------- Those with more advanced aerodynamic toolbags will will no doubt venture out into some of the more exotic shapes,but for amateurs,I believe this form can serve us well.------------------------------------------ Good design and engineering calls for the bare minimum to get the job done........
Aerodynamic Streamlining Template: Part-C
http://ecomodder.com/forum/showthrea...-c-9287-2.html
(1) The ratio does not vary with speed,as it is fixed by the critical Reynolds number which for cars,occurs at about 20-mph.At 20-mph and above,you've established the turbulent boundary layer and Cd minimum which remains constant up to the beginning of transonic flow,at about 250-mph.---------
If I can make a request, when it comes time to do a "Part-D", that it be 3D and include cross sectional information.
There was a thread to turn it into 3D, I'll find it later if someone else does not post it first.
05-29-2013, 09:55 PM
#542 (permalink)
05-30-2013, 07:15 AM
#543 (permalink)
I have been playing with the “new” template, and it appears to be a very close match to the roofline of a seventh generation Toyota Celica. I did a rough PowerPoint overlay using a Celica off the internet. Thank you Aerohead and ChazInMT for all your work in giving us these tools to work with, it is very helpful.
05-30-2013, 04:57 PM
#544 (permalink)
3D
Originally Posted by kach22i
Many months ago someone pushed and I went ahead a posted some extra views of the 'Template' I'd been working on.These were just working drawings.
I'm not sure how the thread was even titled.
A literal 'translation' of the 'Template' would be the 1/2-body generated from the 2.5:1 streamlined body of revolution from which it is derived.
It would be 'wide.'
Considering 'conventional ' body dimensions,the plan-view of the 'template' will look more like the low-drag 'section' profile of Hoerner's just to accommodate the more narrow vehicle.
05-30-2013, 05:01 PM
#545 (permalink)
Celica
It looks really good!
You'd have an easier time than most pushing that puppy into significant low-drag territory.
Nice project car!
05-30-2013, 05:08 PM
#546 (permalink)
How would this airfoil fair?
Link has plot data. Has an aftbody ratio of 1.833 (bit long) but this airfoil looks a bit too fast at the start. Havent compared it to new template yet, as I am on my tablet right now, but earlier on the computer I compared to old template and it seemed way faster and longer.
 : Brothers
 : Dad's
05-30-2013, 06:37 PM
#547 (permalink)
Aero Deshi
Looks good in the part that counts the most from top out to 50%, this is pretty ideal.
Bigger Version
The Following User Says Thank You to ChazInMT For This Useful Post:
05-30-2013, 06:45 PM
#548 (permalink)
how would
I would compare it to Mair's boat tail.
He used about one body diameter length to curve his body into a 22-degree slope,and then just maintained a constant slope as in your rendering.
The 'straight' conical sections are easier to fabricate but must be reinforced from the inside,as they have no eggshell strength of the compound curve and will 'tin can'.
05-30-2013, 08:39 PM
#549 (permalink)
I saw that one, it turns up in a search and I think that I've referenced it at some point - thanks.
I remember the images, a nice blue 3D teardrop with a tight black wire grid over it. It sort of looked like the spaceship Moya in the Sci-Fi cable TV show called Farscape.
Farscape's Leviathan Moya - WIP - Scifi-Meshes.com Gallery
05-31-2013, 02:30 AM
#550 (permalink)
Bless you. Do this:
My ability to help you ends there.
