Old 05-31-2013, 01:23 AM   #44 (permalink)
HyperMileQC
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
The wiper arm is held on by a single nut, which you can take off outside the car (there's a cover over the nut you have to take off first). The nut is on the pivot shaft of course. This leaves the shaft sticking up. If you want that gone too, you'll have to take apart the hatch and remove the drive mechanism from inside.
Thank you! This helped alot. I just removed it and it looks great! I also put some lithium grease on the sticking part to protect from rust. (not showed on the picture) :
Originally Posted by sheepdog 44 View Post
This is what you need to do, i did the same thing to mine.
Rear Wiper Plug - Insight Central: Honda Insight Forum
No problem in the snow. Just remember to kick off the compacted snow in front and behind of each tire. All the snow really adds a lot of weight.
I just wanted to remove the wiper arm, not the entire motor. I will reput it during winter because it will help alot with snow stacking on the window.
Thank you for your input on the fender!
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
