Old 06-23-2008, 02:02 AM   #19 (permalink)
drivenByNothing
arduino 0011 works with ubuntu as well (tested on 8.04) too. In fact, it works better when uploading to the duino whereas XP would frequently tell me the com port was in use.
Whether or not you want to suggest the iduino is up to you. I'll be sure to update you if I run into anything weird.
I tried using different contrast values and nothing is looking anywhere near as good as when it's getting power from USB rather than the old cell charger.
