Would there be a way to attach the covers to the actual lock so you can turn the pizza pan to lock and unlock the wheels. If so you could just have a small hole, as to use some sort of removable handle in the hole. (sorry i'm not doing the best at describing my ideas)
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
