Thanks. I did not have that wiring schematic in my Chilton manual. Could you possibly post the whole page so I can check where the others go?
I want to make sure that one of those doesn't connect to the immobilizer circuit(which is the problem we have been having all along).
I feel that the one common yellow/black is the same as the one at the fuel relays behind the blower/ecu in the cab, which if I'm correct connect to the immobilizer as well.
Also I'm sorry for the ambiguity in my last post. When I checked it, it appeared that all the wires are connected. Not just the wires to the fuel injectors.
