Old 06-03-2013, 10:33 AM   #8 (permalink)
Nevyn
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Just through on Facebook (well, 11 hrs ago):
Hi Facebook friends. I have a small problem. I am in Houston TX, less than 900 miles from completing the first ever coast to coast electric motorcycle journey, and I have had a motor problem. No fault of the motor, the sprocket bolt I installed when I changed the gearing a while back came loose and caused contact with the swingarm bolt, which put pressure on motor shaft causing a cooling fan failure. I am working on a repair, but if anyone is in the Houston area and could reach out to me, I would greatly appreciate it. Thanks - Terry
https://www.facebook.com/terryhershner
