Old 06-03-2013, 05:30 PM   #9 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Originally Posted by aktacoma View Post
faulty results because the avg kept going up as i tested however scan gauge read same temp the whole time so i know its warm enough..
How far / long had you driven before you started testing? I ask because until the entire drivetrain is up to stable operating temperature, efficiency will keep climbing, even after the engine/coolant temp has been at operating temp for some time.
I am in the middle of calibrating my scangauge II in between 1st and 2nd fill does this make any big difference on results?
Not really, since the main thing we're looking at in a test is the difference between numbers, not the specific numbers themselves. Even if it turns out your calibration is off, you should still be able to count on the relative readings to do a test.
