Old 06-04-2013, 11:54 PM   #154 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Originally Posted by a8ksh4 View Post
How are you getting around the smog regulations where you live?...
Ohhhh... I don't think I like the shift knob rotator motor throttle idea, unless it has a cutoff switch....Might need to find a way to do it so that you don't apply pressure to the throttle when you shift...
When I did the conversion of my Geo Metro to electric and had to jump through the legal hoops, I found out that ANY diesel conversion in my area is EXEMPT from smog testing. Also, vehicles older than 1996 (pre-OBDII) are exempt, and the project truck is a '95.
As for the throttle on the stick shift, it could also be a trigger, rather than rotary, or I could simply always apply a slight back-pressure whenever I shift. On my motorcycle, it has an electronic twist throttle, and it doesn't change by accident while steering the cycle. It only twists when I conciously accelerate.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
The Following 2 Users Say Thank You to bennelson For This Useful Post:
a8ksh4 (06-05-2013), Ryland (07-23-2013)
