Old 06-06-2013, 11:34 AM   #18 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
5-6" is close. Drive it over some railroad grade crossings and what is left will tell you what will work. My guess is that 8" is probably A-OK.
I got my 3/8" ripstop conveyor belt from an industrial supply house in Naptown.
It is not a bit cheap. An air dam and two side skirts set me back $100. You are doing this right in one respect. Run one made of cheaper stuff and use it as a pattern for the more durable material. The ripstop conveyor belt is darned near indestructible, but the flip side is that durability makes it a bear to fabricate.
Take your "pattern" and pay the shop rate to get a good professional product that will last for years. Save yourself the agony of sawing/drilling this stuff. Ask me how I know it is hard to work.
Another piece of advice from having done this: clamp the front and rear edges firmly. Your skirt will try to vibrate like an oboe/bassoon double reed. If not clamped firmly even ripstop will wear through .
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following 2 Users Say Thank You to Big Dave For This Useful Post:
Diesel_Dave (06-06-2013), Xist (04-23-2018)
