Old 06-09-2013, 09:09 AM   #40 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by wdb View Post
I'm very interested in hearing how one might go about using a scangauge to correct for speedometer error brought on by changing tire diameter from stock.
Scangauge has a setting screen where you calibrate to the actual speed.
1. set the gps and the scangauge to metric. This gives a more exact reading than miles.
2. if you dont have a gps, then you need to track your odometer on the highway to determine how accurate it is (the green miles markers)
3. Since I have the gps, I dont keep the scangauge on mph since there are only 4 screens at one time.
4. I rarely use my speedometer any more. (in the Q45 or Sportage) since i have the gps.
5. that is why I am a big fan of mounting a gps/scangauge in a location that is easy to see with just a slight shift of the eyes off the road.
http://ecomodder.com/forum/showthrea...uge-18431.html
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
