Old 06-09-2013, 03:46 PM   #13 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Basjoos hand throttle lever I believe used friction like a farm tractor throttle to hold it at the desired speed. There are however, many ways to do this as each vehicle will require a little different approach.
The hand throttle on the Aerocivic can either be locked to hold a throttle setting to act as a "driving with load" cruise control or it can be used unlocked as an alternative throttle control when my foot gets tired on a long trip. The hand throttle lock is not a safety issue since I can easily override the friction lock by pulling the hand throttle's lever back to retard the throttle or, in an emergency, press in the clutch and let the engine rev up until I can get the lever pulled back. At normal freeway cruising speed power settings, the engine only revs up to 4k or 5k when the clutch is depressed.
aerocivic.com
